WD420 no heat / motor jack / Spinning on dry
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries WD420 no heat / motor jack / Spinning on dry
  • #59454
    thankevans
    Hi just been to a WD420 no heat changed the stat we now have heat then lights started flashing for the motor jack plug checked that a bit loose and damp fixed that all working fine washed then put on drying 40 mins in started spinning full pelt and wouldnt stop switched off and scratched head?
    Any Ideas
    #338246
    Re: WD420 no heat / motor jack / Spinning on dry
    There is a spin cycle as part of the drying cycle, it is quite normal and is called thermal spin.
    Thermal Spin
    A thermal spin on the High Heat setting is carried at the start of the of the drying process. The load
    is pre-heated to approximately 50°C by the dryer heater with normal tumble action and pump out.
    The thermistor located in the wash heater will sense the load temperature and when 50°C is achieved
    a 5 minute Spin profile will be carried out at full spin speed.
    During thermal spin the out of Balance detection will operate and maximum speed will only be
    achieved depending on the out of balance condition.
    On completion of the Thermal Spin, the tumble drying process will commence for the period of time
    selected.
    Thermal spin is NOT available when low heat is selected.
