Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › WD420 WASHING MACHINE FAULT PLEASE HELP
- This topic has 7 replies, 4 voices, and was last updated 18 years, 7 months ago by
daveengland.
September 25, 2007 at 11:28 am #30811
daveengland
Participantwashing machine power light flashing on/off also high heat button and time save button flasing at same time 🙁 washing machine will not respond just fills with water any ideas what this might be help just ran out of warrenty.
September 25, 2007 at 2:18 pm #228547Martin
ParticipantRe: WD420 WASHING MACHINE FAULT PLEASE HELP
daveengland wrote: any ideas what this might be help just ran out of warrenty.
Yes, unfortunately it’s an Eeprom Programming Error 🙁
You will need to call out Hotpoint who can call, check and re-programme your machine for you. 😉
September 25, 2007 at 4:13 pm #228548daveengland
thank you for the reply would a general washing machine specialist from the yellow pages be able to reprogramme as hotpoint charge arm and leg ❓
September 25, 2007 at 4:21 pm #228549daveengland
sorry to be a pain but would this problem accur if my young one keeps pressing the buttons
September 25, 2007 at 8:45 pm #228550Penguin45
The electronics in these fall over if you smile at them. Pay Hotpoint the £90, get all and any parts required free as part of the deal.
Type ‘wd420’ into the search facility for this forum only, BTW. Scary reading……….
September 25, 2007 at 10:49 pm #228551iadom
ModeratorRe: WD420 WASHING MACHINE FAULT PLEASE HELP
Hello Mr England, I did try to phone your mobile several times after receiving your request via Repairs@ but was unable to get through as it was switched off when I tried.
I have sent an e-mail to your works address, it basically confirms all that has been said above.
The independent trade does not have access to the software needed to reprogramme eeproms.
September 26, 2007 at 5:34 pm #228552daveengland
can anybody advise why the flashing lights have changed on the panel power light+high heat still flashing but now reduce creases is flashing instead of time saver can this problem b sorted easier
September 26, 2007 at 9:38 pm #228553Penguin45
daveengland wrote:can anybody advise why the flashing lights have changed on the panel power light+high heat still flashing but now reduce creases is flashing instead of time saver
The board has failed.
daveengland wrote:can this problem b sorted easier
No.
