WD420p module
  • #39455
    timdowning
    Wd420P 703050132
    Main module part number required please.
    This is the dual cold supply type with a brush motor and version 3 dryer assy fitted. (If that makes any difference).
    Thanks.
    p.s. whats the score on the programming side of things with this newer type??
    #262477
    helo_75
    2 different modules fitted
    4 eproms
    now, you really have to examine the board to determine wheter it has a j10 connection or not
    eprom? another ball game
    cold fill or hot and cold?
    or 2 cold fills?
    which heater box? is it the late type with the hot flush or not?
    need the right info?
    does it have the ‘y’ fill hose? thats the quick way of spotting it
    you still need to see if the board has a j10 connection or not
    #262478
    helo_75
    C00145013
    is the pcb without j10, which is most likely the one on yours if it has the new heater box
    c00143056 if it has the j10
    C00203613
    is the new heater box eprom
    theyre still available as of now, but soon, youll need a smart card readr, and a smart card to program them… completely different part numbers
    hope this helps
    #262479
    timdowning
    Re: WD420p module
    Many thanks.
