wd440 nightmare
  • #62754
    robbo1973
    Hi all this machine was not starting at all checked normal and then changed module machine lights up door locks but the door light doesn’t come on and machine doesn’t do anything,checked again changed interlock incase found a valve open circuit but still the same.anyone had this before???
    Cheers chris
    #351152
    allan73
    Re: wd440 nightmare
    Have you checked brushes and motor plug connections ?
    #351153
    robbo1973
    Re: wd440 nightmare
    Aint took carbs off but meter through and block seems ok tugged all wires
    #351154
    allan73
    Re: wd440 nightmare
    Might be worth taking them off,it’s usually something on the motor side with those symptoms.
    #351155
    Re: wd440 nightmare
    robinsonrobbo wrote:and then changed module
    Did you do the eeprom/smartcard bit or just swap over the eeprom?
    #351156
    robbo1973
    Re: wd440 nightmare
    Module was from emw
