WD52 Hotpoint
  • #19046
    flash
    hi
    I have got this washer dryer in the workshop. The problem is that I need to change the dryer timer but somebody allready removed the old one
    Ive got the service manual for the machine but cant work out there position on the timer any help please
    Glen
    #181501
    Re: WD52 Hotpoint
    Looking at the wiring diagram for the WD51,61,62 which has the same timer as the WD52 it shows all wiring colours, destination and timer terminal numbers. It will be a bit of a pain but it should be possible to sort using that info.
    If your WD52 manual does not have a wiring diagram let me know and I will send you the WD51 info.
    flash
    Re: WD52 Hotpoint
    Thanks for that Yes the manual has the wirering diagram its me being lazy 😳 Glen
    #181503
    gegsy
    Re: WD52 Hotpoint
    flash wrote:Yes the manual has the wirering diagram its me being lazy 😳 Glen
    :rolls: Glen, Jim doesnt mind helping as we all do but he is as busy as you or I with his own business. You have to help yourself first, If you really stuck or have no tech info to hand then ask away. 😉
    Regards
