WD640 dries how?
  • #54491
    Bones127
    Can anyone enlighten me as to why Hotpoint pass the air through a HOT water screen (which is, incidentally, the only use for hot water in the machine) when in the drying phase for a WD640? It seems perverse to me – not that I’m against perversion 😉
    #319801
    cornwell40
    Re: WD640 dries how?
    Now I’ve got me specs on there’s no mention of WD40 is there :rolls:
    I was just about to post a link to a previous thread. Worraberk 😆
    TC
    #319802
    cornwell40 wrote:Worraberk
    A small town in the Australian Outback.
    :p45:
    #319803
    Hot water screen????
    AFAIK the hot water inlet valve on the early H&C fill machines is connected directly to the soap dispenser and nowhere else. :con:
    The hot water fill only comes in on the wash programmes to ‘top up’ after the initial cold fill when the clothes have absorbed some of the water.
    The pipe from the small filter at the back of the heater box should be connected to one of the four cold valves.
    There is an initial fill through the ‘wash’ valve at the start of any drying programme, for one or two seconds.
    Flushing valve operation.
    During Rinse phase: 2 xs for 15 seconds
    Drying Phase: 1 x before drying phase for 4 seconds
    End cycle: After drying phase, during cool down phase
    Valve Off for 118 seconds
    Valve On for 2 seconds
    Beginning of Drying CycleWash valve: On for 1 second to put water into dispenser hose
    Flushing valve: On for 4 seconds
    Drain pump: On for 20 seconds
    During Drying Cycle
    Drain pump: On for 9 seconds and off for 21 seconds
    Wash valve: On for 2 seconds and off for 510 seconds to put water into dispenser hose
    Condenser valve: On continuously after thermo spin
    #319804
    Bones127
    I’ve just been to the Hotpoint website and downloaded the user manual for this machine. It gets shipped with hot and cold connections, two hoses fitted AND a ‘Y’ piece – with instructions to connect it to the cold supply only – even if hot and cold are available.
    Thank you very much for your responses. I’m sorry I didn’t look before I leapt but it just looked so right – until I poked my head inside the top!
    Thanks again!!
    #319805
    It not hot & cold connections, its just got two seperate cold valves, one is the cold fill wash valve, the other is the four way rinse, fabric conditioner, flushing, condensor valve.
