WDI 9091
  • #28148
    cornwell40
    I know its a long shot but has anyone got the timer connection chart for the above Zanussi oldun.
    Fitted a recon timer the other day and now it won’t spin. as it was a b***ard to swap I want to check my conections first. 😥
    Tony C
    #217123
    Re: WDI 9091
    Jeez that’s old!
    IIRC the diagram was only ever on microfiche… or so I thought. I managed to find a PDF, it should be appearing in your inbox shortly Tony.
    Hope it helps.
    cornwell40
    Re: WDI 9091
    Thanks Ken 😀
    After doing this timer the expression ‘Cut me a bit of slack’ seems very apt. Old dear was insistent I change it even though the original was only tight on the switch pull. With the new one in it feels pretty much the same to me although she’s convinced its better :rolls:
    I just hope its an obvious fault!!!
    Tony C
    #217125
    cornwell40
    Re: WDI 9091
    Cheers Ken,
    Found it straight away with your help 😉
    Tony C
    #217126
    No worries Tony, you’re welcome.
