I have a WDJ1294 – 10 years old but done excellant service
It has the advancing program selector problem (clicking around)
I have already changed the brushes as I had a problem where the drum no longer span up to full speed to dry stuff off. I have also checked the tacho fittment (but not tested it with a meter to verify a connection)
The unit fills with water then turns once – obviously discovers some fault and then moves the timer around to drain (Q)
I need ideas – I am suspecting the motor controller (but they are expensive) so want to validate if there is anything else worth checking before I make that pro-engineer-mend or chuck decision
Francis
