Wdr7543121b diagnostics
  • #95962
    grooster
    Ive got a Beko washer dryer WDR7543121b and the customer says half way through a wash it beeps and stops. She’s very vague with it. Also she says that the last time she tried to dry it didn’t dry correctly. As far as I know it doesn’t come up with a fault code just beeps but again very vague.
    I thought maybe a pump problem would explain a fault in the wash and the dry but no issues there.
    How do you get this machine into diagnostics to check for fault codes. It’s not like the older bekos.
    if anybody can help it would be appreciated.
    Nick
    #461882
    murv
    Close the machine door. To enter service mode, machine is switched off by “on/off” button. “While “temperature setting” button and “end time” button are pressed on together, machine is switched on with the “ON / OFF” button.
    E1 NTC error
    E2 Heater open circuit
    E3 Heater continuously active
    E4 Valve continuously active
    E5 Pump error
    E6 Level sensing error
    E8 No water
    E9 Door lock error
    E10 Door lock continuously active
    E11 Motor phase open circuit
    E13 Motor communication error
    E14 Jet pump open/short circuit
    E15 Flowmeter error
    E17 Spin failed (foaming error)
    E18 Spin failed (unbalanced load)
    E22 Display error
    E23 Door switch error
    E27 Flowmeter/water level control error
    E28 Door locked signal error
    E29 Voltage out of range
    Hope this helps, Murv…
    #461883
    grooster
    Brilliant, thanks very much Murv. Just what I need.
