Hi there, We have a White Knights Eco 83a tumble dryer. I am reliably advised that the problem is that the rivets holding the rear bearing to the drum are failing and we need a new drum. I can’t find anyone to do this job. Any takers? or advice about finding the right person for the job? Thank you
The part number for the drum is 4213-092-44071. The only link I can find is THIS one. if you add the labour charge on top which will be quite considerable as this is a major strip down you may well find it is almost as much as buying a new one. ;(
Without a proper part number there is no way to be certain that drum will fit. I certainly wouldn’t risk £50 on a drum that claims to be genuine but doesn’t include a part number.
