weird fault beko washer WMA642W
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries weird fault beko washer WMA642W
  • #71543
    funkyboogy
    changed rear tub as motor brackets snapped of ..
    built back up everything ok accept when it stops filling up the water is backing up via soap drawer .. its like theirs a blockage in soap dispensor – checked hose and its perfect ..
    this dispenser hose has a u bend so i guess you will get water in their but this is weird , when filling its ok but nearing the end of fill you can see water back up into bottom of soap drawer and eventualy leaks out front ..
    total headscratcher …any idea welcome
    cheers ally
    #381468
    Muv
    Re: weird fault beko washer WMA642W
    Machine not level?
    Soap drawer housing not correctly installed?
    Inlet pipes mixed up. (long shot)
    Water pressure to high at tap?
    Be interesting to know what this problem is!
    Washman
    Is there a vent hose from the drum that is blocked.
    Mike
    #381470
    funkyboogy
    cheers guys . Appliance is level soap in correct pos pipes ok .. others is another vent hose but that’s ok aswell .. I turned water pressure down to. Trickle .. its really weird .. when it’s filling I pulled soap drawer forward enough to see under drawer .. water seems to go into drum then about 10 seconds before the fill ends water backs up and out front .. when I select drain you can see the backed up water disappear.. dohhhh
    #381471
    Hollytree_Technical
    OK – a couple of long shots for you
    1. Its not overfilling is it?
    2. Is the tub inlet hose collapsing/kinking as tub drops due to the extra weight of water
    Jem
    #381472
    funkyboogy
    no not over filling , and hose not collapsing or twisted etc
    its a total head scratcher ..
    #381473
    Muv
    When you say it happens 10 seconds before fill stops, is that when the drum start turning?
    Maybe it’s the revolving drum that’s forcing it back up through the draw…
    jason1970
    Check for blockages in any vent hoses (or even sump, especially if it has one of those ball things in it!). Used to be common in very early Hotpoint washer dryers and was caused by blocked condensing chamber. They had U bend type dispenser hoses too. I guessed it was some kind of pressure build up in the drum. It was never blocked dispenser hose?
