Weird Samsung RS21 problem – no fridge lights
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Weird Samsung RS21 problem – no fridge lights
  • #82646
    holybob
    Hi, had our RS21 for about 7 years. It had the Samsung mod about 4 years ago (for the noisy fan issue, I think, although we weren’t experiencing it). We’ve just done a load of building work and moved the fridge freezer to a new room.
    Now the lights in the fridge won’t come on. The bulbs are fine. The door sensor is fine (I know because the warning beep occurs after it’s been left open a while). I’ve had the covers off an checked the wires and there’s no obvious problems.
    I have however noticed that I don’t *think* the fridge fan is working either. There’s slight build up of ice an the fan never seems to spin up (it moves freely by hand). So it’s almost as if the back panel isn’t getting any power. BUT the temp reading works fine on the LCD, and the fridge IS cold.
    Any ideas please?
    Cheers,
    Bob
    #420491
    holybob
    Re: Weird Samsung RS21 problem – no fridge lights
    Bump – anyone?
    #420492
    LeMarsu
    Any resolution on this?
    #420493
    if the lamp is ok and the unit chimes with the door open
    check lampholder. make sure its making a good contact with lamp. Have had a few lamps that dont seem to make contact in some lamp holders
    check door switch. The door switch is a double. On side is for the door open sensor, the other turns on the lamp
