Were is the thermostat
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Were is the thermostat
  • #65935
    lolasboy
    Hello eveyrone i have an hotpoint BFI620 s/n 60206 and its not heating up have checked heater elementand get a reading of 27 ohms i know the problem could be the PCB but just trying to find out were the thermostat is and how to check it i cant find one listed anywere also i dont have any flashing light only the one that tells me its finished its cycle
    Re: Were is the thermostat
    If the heater is OK then its 99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} certain to be the poor quality Indesit PCB at fault. There is no ‘thermostat’ in this machine, the heater is protected from over heating by internal TOC’s.
    The temperature is controlled by an NTC which is hard wired to the PCB anyway.
    Two different PCB’s fitted, full serial number needed to ID, both around £70.00 or more.
    Strange that there is no error message though.
    #362421
    D13aar
    Hi.
    I’m a dishwasher engineer.
    I must have been to about 30 or so of these over the past 3 years every one needed the pcb changing as the above reply said. They cost £69, so not too bad.
    Hope this helps.
