Wet fridge floor on Bosch fridge freezer kgv28v01gb/1
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Wet fridge floor on Bosch fridge freezer kgv28v01gb/1
  • #88490
    Rednev
    Initially thought it was because of damaged door seal so replaced it with a genuine Bosch seal… however the floor under the salad draws is still wet. 🙁
    Fridge doesn’t feel the coldest either at the moment (was on setting number 3, I’ve now raised it to 4).
    We have quite a warm kitchen in the summer months.
    #438319
    Re: Wet fridge floor on Bosch fridge freezer kgv28v01gb/1
    If there’s a drain hole at the back for the water to run out of, it’s probably blocked.
    Rednev
    Found the hole and it was blocked… will see how it goes. Got a thermometer in the fridge now to test the coldness now I’ve put the setting up from 3 to 4. Thanks
