Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › wet motor
- This topic has 10 replies, 10 voices, and was last updated 15 years, 2 months ago by
raw.
January 23, 2011 at 9:38 pm #60445
raw
Blockedwats the best one to dry out motor after having leak from heater?
January 23, 2011 at 9:49 pm #342182A1TEC
ParticipantRe: wet motor
Would think a hair dryer would be quick.
January 23, 2011 at 10:01 pm #342183Allsorts
Best way would be a dehumidifyer I reckon
George
January 23, 2011 at 10:03 pm #342184iadom
ModeratorRe: wet motor
I’m in the hair dryer camp. 8)
January 24, 2011 at 9:54 am #342185electrofix
hair dryer did one the other day
Zannissi auto fault 51 (i think) motor triac short wet motor gives same fault down to condensation on motor
January 25, 2011 at 12:47 am #342186leavemetogetonwithit
If it’s really wet,
Fan heater, low heat setting. Couple of feet away from front of machine. Lean machine back a bit so air goes underneath. Lid off to encourage upward air flow through machine. Leave it going as long as necessary. Spin motor once or twice during process by turning drum.iadom wrote:I’m in the hairdryer camp. 8)
😯 Well, I never would have thought! 😆
Mike.January 25, 2011 at 8:18 am #342187Cras
Years ago we used to share a workshop with a motor re wind chap he used to place damp motors in an oven to dry them out ….interestingly my dad used to do the same with compressors when repairing a punctured system ,he used to pop them in the oven pipes from compressor out of the door attached to a vacuum pump ,change of oil also and hey presto no blocked sytem ,a trick he picked up from the prestcold factory who he said at the time were not fitting filter driers to there fridges 😯 Cras
January 25, 2011 at 8:39 am #342188Martin
:popcorn:
Sprinkle with seasoning, place on a flat backing tray and place in the oven (middle shelf) 200 degs (Gas Mark 6) for 15-20mins. Allow to cool (20 mins) before serving. 😈
January 25, 2011 at 9:28 am #342189iadom
leavemetogetonwithit wrote:If it’s really wet,
Fan heater, low heat setting. Couple of feet away from front of machine. Lean machine back a bit so air goes underneath. Lid off to encourage upward air flow through machine. Leave it going as long as necessary. Spin motor once or twice during process by turning drum.I have had to do that with four or five machines that have suffered burst fill valves recently.
Still waiting for the new valves to arrive 3/4 weeks later. 😥
January 25, 2011 at 9:56 am #342190Micky 32
Tumble dryer? 😛
January 25, 2011 at 7:44 pm #342191gandh1
micky youve been watching too much youtube…
we had a bosch circ motor die because the salt tank burst, dried it out a bit too quick, and it was clogged full of salt crystals. not sure if it was working beforehand but needless to say it had to be re-hydrated and then dried and was a dodo. so um yeh, if you get a salt tank burst might be worth giving it a rinse before drying…
