Home › Forums › General Trade Forum › Wet vac washing machine emptying
- This topic has 14 replies, 5 voices, and was last updated 8 years, 3 months ago by
Simon46.
January 4, 2018 at 1:38 pm #92974
Simon46
ParticipantJust bought a wetvac as I have admitted defeat. An indesit WD10 fuller than full of water up the door in a top floor flat on kitchen carpet due to the grandson repeatedly trying it. Appliance sliders wont cut it. 39.99 from screwfix. Has a blower function too.
https://www.screwfix.com/p/titan-ttb350 … GwodIo0AMgJanuary 4, 2018 at 2:53 pm #452756Martin
ParticipantRe: Wet vac washing machine emptying
Iām curious to know how you solve it just by buying a wet vac? Opening the door floods the flat and all below it and releasing the filter causes likewise trauma.
January 4, 2018 at 3:50 pm #452757timdowning
Maybe he just sucked the water out through the drain hose?
š”January 4, 2018 at 3:52 pm #452758electrofix
ModeratorRe: Wet vac washing machine emptying
the only chance you have got of emptying the machine is access to the outlet hose. if you have access you may be able to get the machine to start syphoning or use your wet vac to draw the water out that way. this will fail if its blacked by a sock or something like it
another option is to try and empty by filter. this only works if you can find a tray that’s low enough to catch the water as it comes out of the filter. you then loosen the filter till the water trickles out. do not unscrew it completely as it may not close again. this can take time but rushing leads to floods
January 4, 2018 at 4:28 pm #452759Simon46
Couldnt get my turkey baster to pull enough water up the drain hose to syphon into bowl. Because it exits the cupboard next to it 3/4 higher than washing machine. Pump humming due to coin so not blocked. So vac on end of drain should pull it
January 4, 2018 at 4:30 pm #452760Simon46
Will report back if successful
January 4, 2018 at 5:15 pm #452761Martin
timdowning wrote:Maybe he just sucked the water out through the drain hose?
š”Ka-ching!! :tup:
January 4, 2018 at 5:56 pm #452762timdowning
I wouldn’t survive without a wet vac.
It saves so much hassle & time.
I leave mine running longer than needed too just to
stop me having to talk to the customer!!January 4, 2018 at 7:42 pm #452763Simon46
Good idea Tim. Maybe a baking tray on the van too electrofix. Never had to resort to this yet.
Its the future?January 6, 2018 at 9:33 am #452764Simon46
Well that was brilliant. Should have bought one 17 years ago. Sucked water out of drain hose then it ran into bowl by itself by syphon action. Finally opened filter slightly with crevice tool at base of filter and baking tray under machine to get the final bit of water out. So much faster than bowls and towels. My mum has bought one to vac the front lawn (astroturf)
January 6, 2018 at 11:45 am #452765Martin
Simon46 wrote:My mum has bought one to vac the front lawn (astroturf)
Oh the brilliant ideas keep on coming, yay!
January 7, 2018 at 5:17 pm #452766Phidom
I made a useful discovery today. Those little pumps you spin using an electric drill will pump air, so they don’t need to be primed. I was looking for a way to start a syphon, not involving the human mouth. It was actually to bleed a central heating radiator which has its pipes going up high to get over a doorway. It worked well. For a washer I would poke a length of garden hose down through the soap drawer housing and use the drill pump.
January 7, 2018 at 6:08 pm #452767timdowning
Sounds a bit fiddly.
Through the drawer,through the dispenser hose,
through a narrow gap pass the drum then to the water level…January 7, 2018 at 6:33 pm #452768Martin
Phidom wrote:For a washer I would poke a length of garden hose down through the soap drawer housing and use the drill pump.
That is an impossibility. Besides that then assumes you have access more than the OP describes.
Sorry to burst your bubble but a hand drill pump and garden hose are best left solely to your successful radiator problem.
January 7, 2018 at 7:15 pm #452769Simon46
Phidom were you on ezee fix in the 00’s
