Hi all have one of these that is as dead as a dodo . checked the console panel for the switch missing seems to be operating ok . checked main board for burn outs all ok .if you turn mains of wait a few secs then turn back on it gives a quick flash on the console then dead .tightened conns on pcbs no luck . any help please .m
Need to check with the meter there’s 240 volts under load, a test screwdriver can be misleading. Also known a pin of the 13 amp plug to weld itself in the socket.
