Hi having a prob with a hotpoint wf210 select any prog correct lights come on door locks fills for a secound shuts down have had pcb checked and changed door interlock
You should be getting an error code displayed by a sequence of flashing Options neons. Faults without error codes are supposed to indicate O/C motor or wiring.
Check the motor loom & plug,the conductor
breaks inside the insulation,also if the machine
is in a garage it could be a damp module just
remove the seriel port cover and give it a blast
with a hairdryer roy.
