Hi all, my WF240 Hotpoint Aquarius doesn’t wanna work and is flashing three lights: on/off, Energy Saver & Reduce Creases.
Anyone can please help me quickly with it? Thank you!
Rafael
Re: WF240 Hotpoint flashing on/off + Energy Saver + Reduce C
If you are lucky, it’s supposed to mean that the two main pcb’s are not on speaking terms. 😀
It can just be bad wiring connections , with the mains plug removed you need to check the connector plugs on both the facia control board and the main pcb in the base.
If tweaking those doesn’t work then you may have a faulty pcb. 🙁
