wf321 bearings hotpoint
  • #55040
    scaffman
    can anybody tell me if this is sealed drum so the bearings can not be replaced
    before i start the job thank you
    #321787
    timdowning
    Re: wf321 bearings hotpoint
    Have you seen the machine?
    If there is a filter at the front of the machine then it will be a sealed drum.
    The other way to make sure is to see if the front and rear tub are bolted together. If yes it can be split to change bearings.
    #321788
    according to partfinder it is welded, no screwed option for that one.
