Fault with Hotpoint WF440 .Select spin , machine will pump out and start
spin cycle ,Just when you think its ok the drum stops rotating though
it keeps pumping .At same time the n.d.a. happens the mini load light
and on/off light starts flashing .Any ideas ? .The problem started after
her young son had been playing with the switches and timer dial with
the machine switched on .
