WF541 F01 error, Fixable?
  • #57078
    A1_Domestics
    Got one of these where I would normally just pop a board in from EMW but it only spins clockwise and pauses for the counter clockwise spin. Eventually it gives up and flashes the fourth light for F01.
    Couldn’t find a dry joint on any of the relays so I was wondering does any one know which relay is responsible for the reverse spin.
    The Q1 triac (which I’m assuming is responsible for the motors switching) is reading the same as another board I have.
    Cheers chaps.
    #329732
    suedehead1
    Re: WF541 F01 error, Fixable?
    motor triac faulty
    check motor , wiring and connections, could be a broken wire at the motor plug.
