wf541 hotpoint
  • #41301
    dopper
    got a wf540 code = motor triac, spins ok empty but when has a load in this code come up and will not spin.
    is it the motor or the board?
    thanks paul
    #269474
    Re: wf541 hotpoint
    I would think it’s the motor. The diagnostics are probably blaming the triac because the tacho readings don’t match those expected.
    #269475
    lerch
    Re: wf541 hotpoint
    Is the code F01 if so check the taco wires to the motor plug sometimes break off inside and cannot be seen until plug top taken off. If not usually is motor but also just as likely the pcb, sorry not really good news. 😕
    #269476
    Re: wf541 hotpoint
    I had discounted the possibility of tacho problems, assuming dopper can tell the difference between an uncontrolled spin and one controlled by the electronics.
