wf560p belt fitting.
  • #78565
    gazberg
    Hope someone can help please. My moms Hotpoint wf560 has stopped spinning. Disconnected machine and removed top panel and rear bottom panel exposing motor. Found belt had come off.
    Trying to get it back on is a nightmare! Is there a knack to it? Sonply cannot stretch it enough to go onto motor spindle/shaft. Please help!
    #406114
    Re: wf560p belt fitting.
    Before you attempt to refit the belt, open the door and spin the drum as fast as you can by hand, is it totally silent or rather noisy?
    There is ‘a knack’ BTW. From the top, lash the belt to the drum pulley using a strong plastic cable tie, feed the belt over the motor pulley and then from inside the door rotate the drum to wind the belt onto the drum pulley, remove cable tie. Make sure you remove the mains plug first.
    If the drum is noisy then don’t waste your time, the main bearings will have failed and if is bad enough to throw the belt off then you are looking at major expense. If the drum is completely silent then refitting the belt will only be a temporary fix, it will come off again and you will need a new belt.
    #406115
    gazberg
    Thanks!
