WF630
Viewing 6 posts - 16 through 21 (of 21 total)
  • #290908
    LJDomestics
    Re: WF630
    ah i see, so these are seperate, not like the wm spider kits that come with the new bolts.
    think the only thing that will be left at this rate to replace will be a drain pump…lol.
    #290909
    Madmac
    Re: WF630
    I’ve used the 13mm bolts & washers from the 9/5 & WM spider kit as i seem to have tons of them for some reason 😯 They dont foul the outer drum & the washer seems to grip the stainless very nicely.. never had a call back 😉
    #290910
    Re: WF630
    What do you use to fasten the WM spiders on with then?
    #290911
    Re: WF630
    I’ve used the Zanussi ones on Hotpoints. They are the correct shape to fit the dished holes in the drum.
    #290912
    Madmac
    Re: WF630
    iadom wrote:What do you use to fasten the WM spiders on with then?
    A hope & a prayer iadom… a hope & a prayer.. 😉 Nah, i think i re-use the old uns if they look bonny enough.. dont like waste u see 😉
    #290913
    helo_75
    did no1 see the memo about falling out suspension pin?
    hotpoints fix? – put suspension pin in and place a cable tie throught the rear of the pin and tie it up
    i change the pin too, but thats because it dont cost me anything
