wf741 fill level too low
  • #54030
    delta01
    cust complained not washing properly, water level does seem very low approx 25cm above drum , i tried anothr presue switch but its just the same can anyone help please
    #318115
    Re: wf741 fill level too low
    Thats about right with no clothes in.
    Poor wash is usually down to over/under dosing, cheapo detergents, overloading or possibly partially blocked sump.
    Generally, if its tumbling and heating then its not the machine.
    #318116
    delta01
    apparently customer complained that the clothes were dry in the middle
    it seems like its not topping up as the clothes absorb water, anyhow i brought it in and will soak test it in work shop (no pun intended )
    i wondered if she may have overloaded it
    thanks for your reply
    #318117
    25cm is 10″. Did you mean 25mm?
    Mike.
    #318118
    Flyman
    “Clothes dry in the middle” is the normal complaint if the customer is using the wool wash program for normal washing. It is one of the shortest washes but is not suitable for a normal load due to its was action.
