WF840 Pump start delay?
  • #32092
    arosview
    Got a WF840 in the rinse / spin cycles, machine will try to go into spin a full 15 seconds before the pump kicks in. The result is water splashing through the soapbox and a wet floor. There are no error codes showing. I have checked for the usual. Coins in the pipework etc. and the pump is quite free. Any ideas please. Could this be electronic problem??
    Cheers David
    #233583
    phil59
    Re: WF840 Pump start delay?
    looks like a board fault to me
    had this before (we all know what the boards on these are like)
    #233584
    Bryan
    This is a classic symptom of a partial blockage , like a sock or colour catcher thing in the sump hose filter.
    This model does give the drum a bit of a fast turn (during rinses) and if enough water has not been pumped out , it’s forced back out the soap drawer.
    Don’t know about the delay in the pump starting but I’d keep things simple and pay very close attention to the sump hose.
    HTH
    Bryan
    #233585
    arosview
    Thanks Phil that’s what I thought. Customer has paid my call out charge 😀 and is now going to contact Hotp so as to get the board under the 5 year parts and then pay them £90. 😯
    David
    #233586
    arosview
    Thanks Bryan, Just to be sure I’ll go back on Monday and double check. After all I think she would be quite justified in expecting me to pay Hotpoint if all it was, was a sump blockage. But the delay in the pump starting does bother me.
    David
    #233587
    johnnyj
    Almost g/teed a blockage somewhere be it in the sump drain hose or drain, never had to fit a module for that fault. jj
