WF860 30 mins to 37.
  • #35414
    Called to this today, complaint of leaking and of display counting down to 30 mins then jumping up to 37 mins.
    One of the drum half securing screws had snapped just under the soap drawer area causing a slight leak.
    No sign of it getting onto the electrics, what would cause the display to reset to 37 mins?
    HotDog
    Re: WF860 30 mins to 37.
    Hi Jim does it finish the prog or does it keep going bacc to 37min
    #246439
    hotpnt
    if it thinks the pump/sump is blocked it will add a rinse to try to clear, last one i had caught me out, i tried it empty & drained fine but still jumped the time up, changed pressure switch in end to cure it
    #246440
    HotDog
    these boards dont get the wash time exactley right and will extend the time to compensate but your diagnioses could also be correct
    #246441
    Didn’t actually try it and the customer was not there to ask.
    Will watch out for the above on next visit.
    PS. Have you finally gone onto broadband Cliff, two posts in a couple of hours. 😉 😆
    #246442
    HotDog
    I lad tha knows its takes a while to catch on these days
