wf860 whistleing
  • #23392
    wilf
    hotpoint wf860 on spin only there is an intermittant whistle almost musical not a bearing noise (drum or motor) not from the pump. sounds like the noise you get if you blow across a beer bottle only higher pitch. Ive also noticed a ‘slight’ vibration. machine has plastic pulley and belt looks ok
    any ideas? wilf
    #197975
    ace
    Re: wf860 whistleing
    Try a belt, and check thatf the drum is not touching door seal
