WFF 2001 Bosch Wassher
  • #8660
    My WFF 2001 has developed a fault where it doesn’t always fill properly. By testing various combinations I’ve found that it will fill when set to vhot (60 or 90) but not 30. It only seems to fill from the hot.
    I’ve suspected the filters, but they are okay. I thought it might be the cold solenoid but then I found that it will fill from cold when rinsing. And it’s intermittent.
    I’m now thinking it must be the timer, but hoping it’s not as I reckon that’ll be expensive.
    Any ideas would be gratefully received.
    #129849
    Re: WFF 2001 Bosch Wassher
    Sure about that solonoid? Some Bosch have a double one so one half of it could be down. Unplug before removing any panels.
    #129850
    Yes a new Solenoid Valve (Part No: 265772) should solve the problem :tup:
    Question, when you say that there is a double valve, do you mean that the valve is double cold fill or do you mean it has hot and cold in one unit?
    I’m going to try to take it apart tomorrow.
    Thanks for the info. 😀
    #129852
    Dave_Conway
    Double cold valve Pete, the hot one is a single seperate one 😉
    #129853
    Dave_Conway
    PistolPete wrote:I’m going to try to take it apart tomorrow.
    Make sure it’s unplugged first please :zap:
    We’d like you to come back and tell us what you find 😀
    #129854
    Hi guys,
    It’s exactly as you described. I checked both solenoids with my meter and one of them is open circuit. Now I just need to find a replacement on a Good Friday.
    I think I’ll probably swap the hot one around and use it as a cold fill only machine.
    Happy Easter
    #129855
    Dave_Conway
    You can order one online if you’re stuck Pete:
    http://www.bshappliancecare.com/Bosch/boschspares.html
    Click on the “Quickfinder Application” lower right 😉
    #129856
    PistolPete wrote:I think I’ll probably swap the hot one around and use it as a cold fill only machine.
    That will work fine Pete provided you do not use programmes above 60 degrees as that fills first on the hot side. You would have to stick with 40 degree cycles for it to work.
    The machine’s working again now.
    I had a look at the wiring and realised that that I could wire both solenoids in parallel. So that whichever one is used it would still do the cold fill. So I got my trusty soldering iron out and bridged the connections. I didn’t need to touch the hot fill at all.
    Voilla! it works.
    This’ll keep it going until I order a replacement.
    I wouldn’t recommend everyone rewiring their machine, but as a trained electrical engineer, I make certain to take the appropriate precautions.
    Thanks to all. 🙂
