WFF2000GB/11
  • #33360
    richardd
    The power switch on this only works if you hold the power button in. I have tested the switch and it only stays on when pressed. Is the problem likely to be the switch, something to do with the door switch, or a relay not latching somewhere?
    #238404
    gegsy
    Re: WFF2000GB/11
    No it will just be the switch p/no 154079 available from spares@ukwhitegoods.co.uk 😀
    Power off before replacing and have fun with the bowden cable to the door lock as that comes on the unit too 😉
