This machine completes the cycle except the final spin, it drains the water out then leaves the spin/pump light flashing, however sometimes it spins and finishes ok.
Checked Brushes, Pressure System, Valve Coils, Element, changed Pump which pumps out well.
I sat through a 40 degree quick wash this morning and it worked fine 👿 ( No clothes in machine)
Any suggestions would be gratefully recieved.
Turbo
Will have another look at brushes but did seem ok and the wash action seems fine. I was wondering if it could be the pressure switch playing up? Is there a test cycle that can be run on this model. Thanks Martin
Turbo
