WFK 2200GB
  • #32114
    jamesa
    Hello,
    I stumbled across this forum trying to find out whats wrong with my machine, I wonder if any one could help.
    I’ve done a search but came up with nothing.
    It’s stopping mid cylce on the rinse cylce and flashing a code 01 on the display. I can move it on manually and it will finish the cycle.
    It’s getting on a bit now, is it worth fixing or is it new machine time?
    I’d really appreciate any advice on this one, I don’t really want to call someone out if it’s not worth fixing, saying that I could also do without shelling out on a new machine right now 🙁
    Cheers
    James
    #233678
    helo_75
    a bit more info might be helpfull
    looks like a bosch, but could u at least supply the er number from the inside of the door
    then we’ll be able to help a bit more
    thanx
    #233679
    jamesa
    Re: WFK 2200GB
    😳 Sorry about my lame post, I should know better!
    It is a Bosch and the full ER no. is WFK2200GB/12 FD 7611 00516
    #233680
    nomadPaul
    The 01 code would point towards a filling problem , which would also seem to back up our quate about it happening during the rinse cycle . It means that either the appliance is not filling/filling slowly OR its filling ok but the appliance isn’t seeing the water level rising .
    If you put it onto a rinse cycle , empty , can you see it filling inside.
    If no , then it could be the inlet valve ( probably cold ) or the power module .
    If it fills but error codes , i’d be checking the small pressure chamber on the bottom of rear of the drum . It is a small rectangular box with a small black pipe running off it . This chamber can get clogged and give false readings to the water level pressure switch .
    POWER OFF IF INVESTIGATING
