WFL 2450 BOSCH
  • #20307
    barryfast
    Hi all, the conditioner dispenser seems to have a intermittent fault leaves water in some times and some times it leaves conditioner the drawer
    is clean the valve tests OK any idea’s Barryfast 💡
    #186578
    gegsy
    Re: WFL 2450 BOSCH
    Its going to be one or more of these- clogged conditioner feed spouts in roof of drawer,low water pressure,conditioner too thick to syphon or syphon unit itself clogged 😀
    DentedPorsche
    Re: WFL 2450 BOSCH
    Funnily enough just been to a bosch this morning with the same fault. Checked everything and couldn’t find any other cause. I’ve ordered a new dispenser top for it as it is showing signs of black mould in some of the ports. Can let you know the outcome if I get the job back again.
    Brian
    #186580
    gegsy
    Re: WFL 2450 BOSCH
    9 times out of 10 Brian I either rod the spouts with tyraps. Failing that I change just the top of dispenser and bobs your uncle 😀
    superfix
    Re: WFL 2450 BOSCH
    As Greg say’s tie wrap in the holes normally works 😀
    You can also carefully prise down the conditioner section and get an old toothbrush in.
    #186582
    wilf
    Re: WFL 2450 BOSCH
    it takes a little while but I find its worth takeing the dispenser apart and prizing the top inner out its usually full of gunk
    wilf
