WFL2000 MAXX
  • #5972
    Hi, Hope you guys can help I have a WFL2000 MAXX and it gets stuck part way through the cycle (On the fill and drain section) I have checked the pressure sensor and have recently replaced the brushes in the motor and the drin pump.
    I have noticed that all three lights are lit on the from (Active, ready and end) albeit dimly.
    Can anyone help????
    #114871
    Re: WFL2000 MAXX
    Stripe,
    I can only think it possibly a ‘Time Out’ error? Do check the rate at which the machine drains out as I suspect the long hose from the pump to the drain coupling may well be restricted with crud and limescale???
    Other than that I would recommend getting an expert in to check it out 😉
