Element is ok. There is no live supply to the element though. Displays fault 4 with dryer light flashing. also the final rinse light is lit. Suspect main board. Would be gratful for any advice as the board are £174+.
Sounds to me like the heater relay on main module (K3) poor contacts.
The PCB is p/no 295666, or if you up for it you could locate relay and try and match it up 🙂
