washer hangs up on spin just about every time with hardly anything in the drum or with nothing in the drum, pressing start wich normally moves cycle on does nothing have to switch off back on again it locks up completely.
opening door and turning drum then putting on a spin program seems to cure most of the time, the spin program does not work till switched off and drum turned.
looked at brushes on motor they seem fine about 1″ long its just had a new bosch water pump not long had a new door switch not sure what to look at next.
the dryer works fine cleaned out all pipes and filter all good any help would be much appreciated
