What is a rcd?
  • #11177
    The wife’s hoover H160E has stopped working.The lights at the front are on,but when you select a programme the drum does the initial turn and the water comes in a normal,but then it does nothing else.
    I checked the troubleshooter section in the handbook that says that the rcd may have tripped and to reset rcd.
    What is a rcd and where can i find it on this machine?
    #144233
    Dave_Conway
    Re: What is a rcd?
    The RCD is part of your house electrics, “trip switch” is another description for it, normally in the fuse box but that isn’t the problem 😉
    It may be the carbon brushes have worn down in the motor.
    If you are going to check this yourself, power off please :zap: or check Repairs@ for an engineer.
    #144234
    Re: What is a rcd?
    Thanks Dave
