Hi to all,
I’m trying to repair a Siemens KG36NA73/05 freezer the problem seems to be in the no-frost module.
I’ve noted the freezer has a temperature sensor which I believe is OK (because the resistance is changing with the temperature) and also another piece:
I have no way to find exactly what is this piece and how to test it, in the ITV METALFLEX website there is no information at all, it seems this is some kind of thermal switch but I’m not really sure of how to know if it works correctly or where to obtain a replacement.
Could someone be so kind to tell me what is this?. Is this a thermal switch? Is this normally open or normally closed? At what temperature is supposed to change the state?.
The problem is that the freezer is accumulating ice and prevents the upper part (fridge) from refrigerating correctly, so I’m sure this is a problem with the no-frost system. I have tested the heater and the thermal sensor and they are OK so it seems to me the problem is in this piece.
In my tests is always open (infinite resistance) even if you put it in a 100C water or a glass with ice. Is this switch supposed to be closed normally and open starting at 73C? If so it seems is broken, do you know the spare part I can use?.
Thanks to all!
