Had bright white flash from left side kick plate as I turned on cycle which tripped house electric. Then turn machine back on and f06 error so replaced interlock and handle, old lock was bit burnt inside.
New lock won’t lock??
I’m using an analogue tester on lock switch Hotpoint WMXTF942K washing machine.
Obviously the machine is unplugged…
Switch pin no.s are 321 whichfit into lock with pin no.s 543.
5into3, 4into2, 3into1.
On switch I only get a reading when black probe in middle pin no.2 and red probe in end pin no. 3. What does this mean?
Also there’s only the motor under where the flash came from could it be that?
The inlet water tray was very blocked black slime which is sort of above motor…. inlet tray clean n replaced. Please help my teenager needs clean clothes lol.
