What resistor do I need?
Viewing 15 posts - 1 through 15 (of 18 total)
  • #23370
    Maplins have just opened a brand new store in Basingstoke, so I pop in there for a replacement resistor, like you do!
    I plonk the module on the counter and point to the duff resistor (see photo). Shop assistant says, “We’ve got hundreds of them!”…..But I only want one, I replied! He continued….”but you need to look it up in one of our catalogues first, then give me the stock number before I can pick it for you?”…..Have you got a catalogue I can look at then?…”Sorry sir, we’re waiting for them to be delivered from head office, but Alan our technical bod would be able to help you but unfortunately he’s off sick at the moment!” 😯
    So having ventured into a store that had thousands of resistors in stock, probably hundreds just like the one I needed, I felt like a eunoch in a brothel….and left empty-handed! 😥
    So if anyone can glance at the photo and tell me what I need, I will be eternally grateful? I guess it’s what Maplins call a ‘wire wound resistor’ but I need to know its wattage I believe? Preferably if you could give me the Maplins Catalogue number, then I could go into their store again and grab one for myself? 😀
    #197882
    timdowning
    Re: What resistor do I need?
    Do you have an account with connect? part number RC55K6. This is a 5 watt resistor which I think is right. This is the same resistor used on servis modules. (Maplins do a 2 watt 5k6, d5k6. Dont think this will suffice).
    #197883
    cab
    nice photo, its a long time since I did any electronics but I believe 5k6 is another way of writing 5.6k! as in kilowatt.
    cab
    #197884
    cab wrote:as in kilowatt.
    A 5.6 kilowatt resistor?…pull the other one, its only a Merloni module not a Empire State Building lift controller!
    #197885
    timdowning
    http://xtronics.com/kits/rcode.htm
    #197886
    cab
    told you I havent done much electronics in a while it would be ohms not watts!!! daaaa!
    cab
    #197887
    Martin resistor is 5.6 KOhms (5600Ohms) 5 Watts. You can put there even one bigger(10Watts) if is fiting on electronic house and don’t touch or is not near to anything made from plastic because he’s getting quit hot… you can find one of this on most of AEG programmers(timer)
    If you don’t find 5k6 you can put two 12KOhms(3Watts) resistor in paralel instead.
    #197888
    At closer look in your picture it seems to be only 3Watts resistor.
    #197889
    jeremy
    on a new module they replaced that resistor with a cement encased noninflammable version. if its the module i think it is .
    #197890
    Thanks guys, so its a 3 watt or maybe a 5 watt then? It actually fits a Merloni jeremy so which one of this lot is best for me to get? :-
    http://www.maplin.co.uk/Search.aspx?criteria=wire{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}20wound{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}20resistor&doy=15m12&source=15
    #197891
    jeremy
    there isnt a 5.6k listed ?
    #197892
    jeremy wrote:there isnt a 5.6k listed ?
    Oh flip and darn! Now what am I going to do? (Where’s andy2 when you need him? :rolls: )
    I’ve got Mrs Woman’s duff module to sort, she can’t spin her smalls, her kids are running around in mucky underwear, all for the want of a 5k6 resistor…..Blimey! 😕
    Who was it that said… “A resistor, a resistor, my kindom for a resistor!”
    Hey! Ho!
    #197893
    Martin114
    I get mine from RS Components (rswww.com) item no. 199-5460
    they are 5k6 6watt.
    #197894
    Martin114 wrote:I get mine from RS Components (rswww.com) item no. 199-5460
    they are 5k6 6watt.
    Thanks! 😀
    Is it this one?
    http://tinyurl.com/ycg4hz
    #197895
    Martin114
    Thats it Martin
