What size wire for a 9.5W electric shower?
Home Forums Public Support Forums Spare Parts Help What size wire for a 9.5W electric shower?
  • #25889
    Nina
    Firstly I just want to apologise if this post isn’t in the correct area of the forums.
    I was just wondering what diameter wire is needed for a 9.5kW electric shower.
    Many Thanks
    Nina
    #207983
    Brains
    Re: What size wire for a 9.5W electric shower?
    Nina
    You need to have a registered electrician look at this as there are number of factors are involved such as length of cable run, external fault loop impedance, method of installation etc. that will determine size of cable required.
    Also, is your incoming supply capable of supporting an extra 9.5kW of load?
    I suggest that you look at niceic.org.uk for an Approved Contractor in your area.
    This work may also need to be notified to local Building Control under Part P of the Building Regulations.
    Regards
