Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › What sort of inspection lighting do you use
- This topic has 6 replies, 6 voices, and was last updated 14 years, 2 months ago by
trusted.
January 23, 2012 at 3:15 pm #67519
trusted
ParticipantHave been managing for years with a rechargable torch, but it can often let me down by needing charging or a new bulb.
Recently I have started using a mains inspection lamp with a 60W incandescent lamp, but they are not robust enough and I am often replacing the bulbs.
So I was wondering what everyone else uses for illuminating the appliances you are working on?
January 23, 2012 at 7:14 pm #367681HotDog
ParticipantRe: What sort of inspection lighting do you use
Petzl head torch gives you two free hands and shines were you look wouldnt be without it very bright not cheap 25/30 pound
January 23, 2012 at 10:21 pm #367682agwarn
Petzl head torch aswell and a decent LED Lenser torch, not cheap but very robust, really bright and the batteries last for ages.
January 24, 2012 at 10:19 am #367683EFS
Wind up LED torch never needs batteries and up to now has proved to be indestructable.
Steve
January 25, 2012 at 3:56 pm #367684trusted
Thanks to you all for bothering to comment. I thought long and hard about this and have finally decided to go for a
Petzl PIXA 1 ATEX Headlamp/Torch. Ordered one through Amazon Marketplace for £26.99 with free delivery.This review on Amazon also helped make up my mind
“I’ve used head lamps before but never found the right one for close up electrical work. The Petzl PIXA 1 has changed all that. The LED and diffuser provide a uniform light which is perfect for close up work. The head strap is comfortable and the robust build and positive switch means you can store the lamp in your tool bag without accidentely switching the lamp on or damaging the lens.Its a must have for Electricians or any other trades that finds themselves needing hands free, close up work in bad lighting conditions”.January 25, 2012 at 4:08 pm #367685garn
ring inspection lamp used one for 5years charge it ones a fortnight( http://www.amazon.co.uk/RING-RIL2500-Co … 530&sr=8-1
£29.99 Halfords If You Have a halfords Trade Card Which Is Very Handy Discout Its £22.00.paul
)January 25, 2012 at 10:42 pm #367686johnnyj
I lose that many of them or forget to switch them off when i throw them in my toolbox i just buy cheap and cheerful rechargeables ones now.
