What was the best machine ?
Home Forums General Trade Forum What was the best machine ?
Viewing 15 posts - 1 through 15 (of 32 total)
  • #71512
    Muv
    Hi all
    A question for everyone
    What was the best machine ever made by hotpoint
    And the best Made by Hoover?
    Please state why if possible..
    And also what machine out of any make, is the easiest to work on, and the most reliable..
    Seamy
    Re: What was the best machine ?
    Most of the old Zanussi’s were very reliable, i’ve worked on a 30y old Zannusi Z9191T model & a 32 y’old Miele washer
    #381324
    Muv wrote:What was the best machine ever made by hotpoint
    Empress of course!
    Muv wrote:And the best Made by Hoover?
    0307 without doubt!
    Muv wrote:And also what machine out of any make, is the easiest to work on, and the most reliable..
    0307 again.
    Not sure exactly the reasoning behind your questions though Martin? 😕
    #381325
    Muv
    Thanks for you contribution Martin
    No real reason for the question, just thought it would be interesting to see the results..
    Muv
    Never heard, or seen a 0307 till few minutes ago courtesy of YouTube…
    What a simple looking machine, but it never had a drain pump?
    Great wash action though
    #381327
    Second the Hotpoint Empress and add the Hotpoint 1502 with the Controls Company timer as the best top loader.
    #381328
    Seamy wrote:Most of the old Zanussi’s were very reliable, i’ve worked on a 30y old Zannusi Z9191T model & a 32 y’old Miele washer
    1826 then is your answer? not yet known Miele brand a Hotpoint or Hoover. 😉
    #381329
    DrDill
    Bendix home laundry centre
    Sent from my iPhone using Tapatalk
    #381330
    Alex
    Question is a bit like “Who was your favourite Bond”? Most would say the first one they ever saw.
    I think with this, those that grew up with the old Hoover/Hotpoints of the 60’s 70’s would give their favourites.
    With Hoover, I would think they each had their own strong & weak points. The good old 3224/3226 were over-engineered lovely bit of kit but a lot to go wrong.
    The next generation with the planet gears etc on the motor, 3208, 3203H, 3223H etc were a nightmare. Rusting tubs, poor quality timers, motor clutches noisy etc.
    Then there was the “Matchbox” range, 3236H, 3243H etc. These were my favourites. Not for reliability, but were very functional, and fairly easy to work on.
    Evolved into the 100 range, then it started to go pear-shaped. Poor bearings (tapered) design, A3008, A3060/3062. Then the 80’s with A3112 etc with poor mechanism on fascia/control for the door opening due to the plastic fulcrum that used to break.
    I suspect a lot of answers will come from engineers who were familiar with the product & loved working on them.
    Alex
    #381331
    Alex wrote:Question is a bit like “Who was your favourite Bond”? Most would say the first one they ever saw.
    Mine was a Candy 262. If I ever see one again I’ll likely break down as it truly was enough to drive a grown man to tears. 😉
    Doubt if any of you guys were familiar with this machine but the Bosch VT570 was THE best washer dryer of any I have known. Built like a brick outhouse, easy to work on, simple in operation. Proper direct condenser drying system inside the drum (non of this fan assisted fluff chamber crap). Massive drum, bearings never failed, induction motor/clutch unit with enough torque to drive a ferris wheel. Fully removable double skinned front and side panels (outer panels white stove enamel. Inner panels sheet steel)
    And because they were expensive to buy and needed lots of space only the rich and famous bought them ( from Harrods mostly). So access and getting paid to fix them never an issue but more a pleasure………..Happy days! 8)
    #381333
    Martin wrote:Doubt if any of you guys were familiar with this machine but the Bosch VT570 was THE best washer dryer of any I have known. Built like a brick outhouse, easy to work on, simple in operation. Proper direct condenser drying system inside the drum (non of this fan assisted fluff chamber crap). Massive drum, bearings never failed, induction motor/clutch unit with enough torque to drive a ferris wheel. Fully removable double skinned front and side panels (outer panels white stove enamel. Inner panels sheet steel)
    and made by AEG IIRC!
    #381334
    Seamy
    And also what machine out of any make, is the easiest to work on, and the most reliable, 😉
    Not sure that Hotpoint & Hoover were the most reliable, its more likely that because they were a British machine and very common, with parts being readily available for them making them easy to repair, but they were in my humble opinion not a good as the aforementioned appliances, how many Hotpoints or Hoovers have you seen over 30 y’old?
    I’ve seen many many Hoover & Hotpoints but by time for the 30 candles they were rusted through.
    #381335
    I have seen several Hotpoint Empresses that were 40 or 50 years old in full working order and without any rust either. 😛
    #381336
    captaincaveman1
    About a year ago I got called to a zanussi SL218T circa 1980ish still on a D&G policy and still working apart from “A knocking noise every now and then” turned out the tin worm had gotten hold and a suspension leg support had rotted and broken off the cabinet bottom so I had to finally give it its last rites!. I myself have an Zanussi WDJ1074 bought in 1992 and have only replaced the brushes on/off and door switch in all this time.Not a chance of their latest offerings doing the same though!.
