What washer/dryer
Home Forums Public Support Forums Buying Advice What washer/dryer
  • #80690
    duffpaddy
    I will be moving into our new house which has a small utility room and doesn’t have room for both washing machine and dryer. Long term I will get a shed and put a proper dryer in there. In the short term I think i’ll just get a washer/dryer.
    I know they are not reliable etc but at the moment I do not have a option. I am presently living in an apartment with a bog standard Indesit which has caused a few problems.
    Budget is about €500 – €600 and would put a wash on every second day as have a baby.
    #413759
    don
    Re: What washer/dryer
    duffpaddy wrote:
    I know they are reliable etc but at the moment I do not have a option.
    I hope you meant to add the word “not” 😉
    Difficult one this :rolls:
    If you spend little as it’s only potentially short term you won’t get reliability or build quality. If you buy the best which is the Miele you are on overkill unless of course you keep it long term. If you take the middle ground ie Bosch you will get a good all rounder.
    Do you have room for a small compact dryer? If you can muster a 20″ square by 22″ high area I would get the washing machine of your’e choice backed up by the small dryer.
    HTH 🙂
    Don
    #413760
    duffpaddy
    sorry – yes I meant “not reliable”. Since edited.
    #413761
    gandh1
    a warm breeze drys better than most washer driers. either go for an £800 bosch, £1200 miele or stick with a washing machine, and get a dinky 3kg vented dryer for £150!
    Mod edit: Removed slang for wind as it may cause offence.
    Don
    #413762
    duffpaddy
    I think I might go for a Bosch as Im concerned about the repair costs for a Miele.
    Any particular Bosch (or Miele) that you’d recommend?
    Any particular compact dryer that you’d recommend?
    #413763
    don
    Miele only make the WT2780 in freestanding.
    Bosch WVH28360GB washer dryer.
    Hotpoint V3D01P front vented compact dryer.
    White knight WK38AW rear vented compact dryer.
    HTH 🙂
    Don
    #413764
    duffpaddy
    Cheers. The Miele is out of price range. I cant seem to source the Bosch one in Ireland – any other suggestions?
    These would be the main stores in Ireland :
    http://www.powercity.ie/
    http://www.currys.ie/category/washer-dryers/2.6
    Maybe the BOSCH Avantixx WVD24460GB?
    #413765
    don
    Strange as it’s on the Bosch Ireland website here if you can’t obtain that particular model then yes the WVD would be an alternative.
    Don
