whats the best washer/dryer for £500
Home Forums Public Support Forums Help And Support Washing Machine Help Forum whats the best washer/dryer for £500
  • #24751
    philz
    looked at the lg wd12336ad £449.95 but still unsure
    please help
    reg phil
    #203186
    Re: whats the best washer/dryer for £500
    Have a good read of this article before you plump for LG. http://tinyurl.com/zez8h
    Then ask yourself if you cannot possibly find room for a separate dryer. There is only one advantage to a washer/dryer, they save space and nothing else, there are many drawbacks to having a washer/dryer but if you really cannot avoid having one then you should look to Bosch or other BSH group products before LG.
    Turbo
    Avoid them if you can but Zanussi would be my choice, if you can get a non Jetsystem model that would be better as the limescale blocks these up early on in their life. Also buy the split cabinet version as these are best.
    Turbo
    #203188
    Apart from the fact that the Electrolux group which includes Zanussi, Bendix & AEG amongst others have now introduced a one piece, sealed outer drum on many of their recent machines. This means that there is no bearing or drum shaft repair, also should you be unlucky enough to lose a sock, bra wire, coin or similar object between the inner & outer drum and be unable to retrieve it from either the heater or sump hose apertures you would need a complete drum replacement. 😥
    Here’s a good bet from this link 😉
    If you want better then the only option is a Miele at twice the price.
    philz
    thanks for all your help ill keep lookin now 😯
    #203191
    Turbo
    Installed a brand new zanussi washer dryer on Fri which still had the bolted drum Jim but as you say they could land up with a welded tub we just dont know whats under the bonnet at the moment.
    Turbo
    #203192
    Turbo wrote:Installed a brand new zanussi washer dryer on Fri which still had the bolted drum Jim but as you say they could land up with a welded tub we just dont know whats under the bonnet at the moment.
    Turbo
    Very true, there is a good chance your Siemens W/D will have Red Dwarf and pasta connections. 😉
