Whats the Difference?
  • #30221
    Dopey113
    with a twin motor (compressor) and two thermostats
    compared to just the 1 of each? are there any real advantages to having 2 or is that just its twice as likely to go wrong?? or is it you can use them outside?
    Thanks Tony
    #226407
    trio
    Re: Whats the Difference?
    YES YOU CAN USE OUT SIDE,
    JUST LIKE HAVING TWO MACHINCES ON TOP OF EACH OTHER
    WORK JUST AS GOOD
    #226408
    The difference is that on a single compressor the fridge thermostat determines the cut in and cut out, also “regulating” the freezer temperature. If the ambient drops below about 10C then you run the risk of the fridge not getting warm enough to cut in and you get the freezer defrosting.
    On a twin compressor machine, with twin stats or sensors, that generally won’t happen.
    However a read at this article will likely provide much more info.
    HTH
    Dopey113
    Ok thanks for that, so in general a twin is better for outhouse/garage etc, and the single is for inside the house, which is what i am getting and using it for
    Thanks for your help again Tony
    #226410
    helo_75
    are there any twin compressor units these days? i know a lot of the manufacturers have now started putting the solenoid on the suction line?
    #226411
    Yeah, I’ve not seen a twin pot machine for a long, long time.
    And, anyway, whilst it may be better it’s still not without risk and, having a fridge freezer sited outside its climate class will invalidate any warranty or insurance cover.
    Dopey113
    Yes i was going to but the side by side fridge/freezer from curry’s (in the sale it was £499) and that had the twin temp and compressors, but 2 things put me off 1 it was a Samsung and the other was it only had the water that you had to fill by hand
    Then i saw the LG for £50 more and it had a plumb in water dispenser (with a filter) and ice maker crush/cube ok it was a little smaller but there’s only 3 of us in the house and it was more that enough to convince me it was better than out first choice, but if i had to buy again i would have gone to comet to buy it (i know its the same company) but on line it was a little cheaper and free delivery too (curry’s was £50) so i am picking it up, but curry will dispose of your old units for free and comet will charge you , in the end my neighbour is taking my old units and going to use them (Hotpoint fridge and a up right freezer) so its 6 of one etc………….
    #226413
    Before you go down the Korean route, have a read at this one about LG and also this one about Samsung nor to mention this one on Samsung fridges especially
    Honestly, I can’t recommend either as I consider both to be poor copies of the actual US stuff in both performance and reliability. The support on both brands is nothing short of woeful if anything goes wrong and well documented as being so.
    As an afterthought…
    The Co-Op that new Beko side-by-side, the ADP930S, for £599 but I’ve no idea what it’s like as I’ve yet to see one but it can’t be any worse that the Korean stuff. Only thing with Beko is that parts are liable to be a lot cheaper when the time comes.
    Might help, dunno.
    helo_75
    comet and currys are not the same company
    currys is owned by the dixons group, comet are owned by kesa
    thought that was common knowledge?
    #226416
    helo_75
    oh , and just cos the samsung says twin cooling, does NOT mean it has 2 comperssors!!
    im unaware of ne samsung with 2 pots?
    ne1?
    #226417
    Dopey113
    helo_75 wrote:oh , and just cos the samsung says twin cooling, does NOT mean it has 2 comperssors!!
    ne1?
    You could be right, i cant find the thing now on there site since the sale has finished, but im sure it was as i said, that’s the reason i asked the Q
    Anyway picking the LG up later from curry’s, just had a look on line and it has a 2 year warrantee and not the 1 year (hoping i don’t need it) but i know uk whitegoods do an extended one, but i don’t know how much it is or for how long, its worth thinking about if i did know
    #226418
    Hi Dopey,
    Ehm, that’s my fault. 😳
    It’s something I don’t like to push in people’s faces so it’s not exactly made easy to find I’m afraid. I will get around to sorting it, honest. 😉
    Here’s the price list for download as a PDF and you’re looking at the “2+3” column to give you five year cover. You can do it monthly, but that way is the cheapest option.
    You should find it just a tad cheaper than Comet or Currys. 😉
    HTH
