I don’t do many oven repairs . I am replacing the element of this fan oven and tested this mounted on the frame in the bottom RHS corner.
Is this a heat fuse ??
It either an overheat stat or to bring on the cooling fan (not sure which on these) but if the warm air fans running it wont be that at fault if its just blowing cold its more likely the fan element
Thanks Captain.
The stat is O/C so then I suppose its an overheat stat. I just wanted to know what its function was. I don’t think there is anything wrong other than the element.
Cheers.
