Where can I find the thermostat in my frostfree frigidaire F
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Where can I find the thermostat in my frostfree frigidaire F
  • #88066
    oldboat54
    Is it in the ceiling of the fridge where the light is?
    I’ve tried to remove this but can only take off the light cover.
    There is a dial in front of the light with numbers 0 -7 so I’m thinking that the thermostat in there, am I correct? The problem I have is the fridge/freezer is not getting cold.
    Have checked the fan an that is working and the compressor sound like it is working.
    Can someone help me out?
    Kevin
    #436900
    Re: Where can I find the thermostat in my frostfree frigidai
    Model please
    bryan
    #436901
    oldboat54
    The model is FRC150FF
    I’d put it in the title but it’s been cut off!
    Kevin
    #436902
    mike4369
    If you Google “Frigidair fridge thermostat” there are loads of links to images and if you enter a model number it may even show you where it’s located
    #436903
    The part Number is 1112797 and yes it is behind the light housing. You just need to be forceful removing the plastic lens..There was some that had a small screw holding the lens in place.
    As this is a frost free unit the common faults were that the duct from the freezer got blocked with frost from the freezer and this jammed the fan.
    Try defrosting the unit by switching off for 24 hours with both doors open and then restart it.
    The defrost timer is on the top under the lid
    Bryan
    #436904
    oldboat54
    Hi Bryan
    Thank you for the info, very good of you.Will let you know how I get on.
    Kevin
    #436905
    oldboat54
    Hi Bryan
    I tried leaving the doors open over the weekend. But sad to say it never worked.
    Kevin
    #436906
    Is the compressor and fan running ? or does it try then make a click ?
    Bryan
    #436907
    oldboat54
    Hi Bryan
    Yes they are both running.I left the doors open last night and switched on this dinner time.Not sure if there was a click when I switched on. It’s still running warm but not hot.
    I’ve also seen somewhere on this model there is a defrost timer switch.Could that be a problem? If so where is it on the FRC150FF
    Kevin
