my integral fridge freezer has finally died on me! Any ideas where I can get hold of a replacement or which other manufacturer models will fit in the MFI cabinet space?
Re: where can I get hold of a replacement for my MFI APM6825
Hi caa
Most manufacturers produce integrated fridge freezers. If you can post up the height of the current machine and the door split fridge to freezer ie 50:50, 60:40 or 70:30 i`ll post up some recommendations.
As Don suggests the major problem is not getting one to fit the hole more its rather on with the correct door configuration. From memory we have replaced one of these with a Baumatic BR27B but the door ratio was wrong and we had to connect both doors together to make it work. Not ideal but at least it looked OK 😯
